dpf audi a6
jan.bork
dpf audi a6
Příspěvek od jan.bork »
nejde mi spustit regeneraciu DPF, je to audi A6 , 3.0tdi ,
do kodovania zadam 10016 , jednotka prijme prikaz ale nic sa nedeje
diagnostika vyhadzuje chybu P242F , blika zhavenie , kontrolka DPF nesvieti motor po nastartovani stale po 20 sekundach v nudzovom rezime
uz nevim co s tim nejaka rada?
MareC3k
Příspěvek od MareC3k »
3.0l V6 CR-TDI*
Prerequisites:
Ignition ON
Engine ON (Idle)
Oil Temperature above 70 °C (see MVB 007.2)
Particle Filter Load below 68g (see MVB 104.3)
If the Particle Filter Load is above 68g the Particle Filter needs to be replaced since the car may burn down when regenerating.
Engine Hood CLOSED
Parking Brake ENGAGED
Transmission in (P)ARK
Temperatures at the Exhaust System may rise up to 300 °C!!!
No Fault Codes Stored
Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Control)
The Regeneration may take up to 40 minutes, the engine speed automatically increases to about 1500 RPM.
[Select]
[01 - Engine]
[Coding-II - 11]
Start Regeneration by Entering 10016.
[Do It!]
[Meas. Blocks - 08]
Select all 3 Groups at once 100, 101 and 102
[Go!]
MVB 100.1: Engine Speed
MVB 100.3: Regeneration Counter/Timer
MVB 100.4: Regeneration Abort recognized (0 = No Abort/1 = Abort recognized)
MVB 101.4: Regeneration Status (001 = Heating Up, 010 = Regeneration, 100 = Cooling Down)
MVB 102.1: Temperature before Catalyst
MVB 102.2: Temperature before Particle Filter
[Done, Go Back]
[Close Controller, Go Back - 06]
a este musi byt viac ako tusim polovica nadrze nafty.
Audi A6, 3.0TDi AvantQ, BMK 165kW@220kW, VW Touran, 1.9TDi, BKC 77kW@96kW, '06
superb10
Příspěvek od superb10 »
ked mas chybu v RJ motora regeneraciu nespustis
