Xenony Octavia II facelift
Arle
Příspěvek od Arle »
Na Octe som vymenil halogeny za xenony .
Lavý xenón mi nesvieti Log vykazuje dolu uvedené chyby.
Viete poradiť ako xenony rozchodiť?
Address 55: Xenon Range Labels: 5M0-907-357.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 8388607
Shop #: WSC 00000 000 00000
Part No: ID- Lfe 29B
Component: AFS-Lst.-Modul l 0004
Coding: 00000255
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
5 Faults Found
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Voltage: 11.08 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Octavia II 1,8 TSI
hamony
Příspěvek od hamony »
rekl bych ze to nemas nakodovany na xenony
Arle
Příspěvek od Arle »
nevieš poradiť ako to nakodovať?
Octavia II 1,8 TSI
