Problem klima- sahara netoci se na plno
Petmen
Příspěvek od Petmen »
Konector nebyl zniceny prave
Seat Leon Fr 2.0 Tdi Cr 200ps 420Nm
Nam jednou nekdo prepinoval vnitrni vetrak na P406...pak to vyres ze
Auto furt hvizdalo a netopilo dovnitr
3 dny jsem s tim laboroval (LOL)
dhfool
Příspěvek od dhfool »
Tak diagnostiku a live data. Najdi si podmínky odpojení kompresoru a kontroluj když to nechladí.
A/C cut-off Codes
0 = Compressor on (no shut-off requirement of the A/C compressor detected)
1 = Compressor off (refrigerant pressure was or is too high)
2 = Compressor off (blower motor circuit)
3 = Compressor off (refrigerant pressure was or is too low)
4 = Compressor off (display not currently intended)
5 = Compressor off (no engine start or no engine speed detected)
6 = Compressor off (A/C system switched off, ECON-mode activated)
7 = Compressor off (A/C system switched off, blower switch in position 0)
8 = Compressor off (outside temperature was less than 1.5°C and is still less than 2.5 °C)
9 = Compressor off (display not currently intended)
10 = Compressor off (Low voltage)
11 = Compressor off (display not currently intended)
12 = Compressor off (shut-off request from Engine Control Module (ECM) via CAN)
13 = Compressor off (voltage supply terminal 30 too high)
14 = Compressor off (Evaporator Temperature)
15 = Compressor off (display not currently intended)
16 = Compressor off (activation A/C Compressor Regulator Valve -N280- implausible)
17 = Compressor off (no signal or implausible signal from High Pressure Sensor -G65-)
18 = Compressor off (engine speed too high at standstill)
19 = Compressor off (shutoff request from Vehicle Electrical System Control Module via CAN)
20 = Compressor off (refrigerant loss-currently V8 Touareg only)
21 = Compressor off (Outside Temp < 2 degrees C, without recirc mode on)
22 = Compressor off (Outside Temp < 2 degrees C, Inside Temp. < 10 degrees C)
Pokud bude podle této tabulky kompresor zapnutý, tak zkontroluj teplotu na výparníku. Pokud tam bude cca +-2 °C, tak může být vadný, nebo špinavý senzor osvitu.
Pokud nemáš diag, tak to svěř někomu, kdo ví co dělá. Ve výsledku ušetříš čas i peníze.
Škoda Superb II 1.8 TSI DSG-7
SuperVAG Comfort VW/PSA 2017
BMW DIS/GT1 v57 /ISTA D
dhfool
roman1648 píše:Nam jednou nekdo prepinoval vnitrni vetrak na P406...pak to vyres ze
Mi povídej... Přijeli borci, že se po bouračce auto přehřívá, ale jenom když jede, na místě OK. Tak že si udělali hlavu a pořád stejné. Hmm.. stojím před autem sahara jede a koukám, jak mi plápolají nohavice...
dreizig5
Příspěvek od dreizig5 »
(rofl) (rofl) (rofl) tak to je mazec (LOL) (rofl) hlavně že měli smysl pro srandu (rofl)
Petmen
Senzor osvitu je ten cernej cverecek v palubce u okna??
Petmen
Tak kompresor ko. Nachladi jen 18'C a tlaci malo
to je dobry no na 2 roky starym autě..
Petmen
Nemyslim si ze odeslo starim, ale tim ze bylo bourane. Takze se vnem po narazu neco pooooo
No to nevim pokud nesla rana na nej primo...to zase ne
Petmen
Byla na nej ale vypada v pohode
