kit na vymenu rozvodov INA
Napsal: 01 srp 2014, 06:53
od sky59
Zdravim hned zrana....,
tak uz k tomu doslo o tyzden menim rozvody na ASZ v popise. Idem do servisu nech mam aspon aku taku zaruku, peniaze v tomto pripade nepovazujem za prvorade.
Chcem sa vsak spytat, ci ma niekto skusenosti s kvalitou rozvodov od INA. Supravu mam kupenu uz skoro 2 roky a rad by som vedel, ze ci za ten cas niekto nepouzil tento KIT...?
Zubaty remen je Made in UK, napinacia kladka je z Kanady (viem ze to nic nezarucuje len pre informaciu to uvadzam)
Mam v servise pripraveny uz "zalozny" original KIT ale nevedia ani kto to vyrobil, je to pre nich original a basta.
Repasovane cerpadlo som odmietol, mam uz kupene nejake s kovovym telom cerpadla Made In Germany, firma sa vola na 4 pismena a tusim zacina na G... )nepamatam teraz)
Urobil som aj nejake merania pred vymenou, pretoze som s autom nadmieru spokojny tak aj pre pripadnu pomoc ostatnym to sem pripajam:
motor zohriaty po 30km jazde:
Mozete pripadne okomentovat ze ci je vsetko naozaj ako ma byt....
Nerobil som csv, su to po dve merania...
Saturday,26,July,2014,10:37:57:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Address 01: Engine (038 906 019 HJ)
10:37:15 Group 013: Idle Speed Smooth Running Control
0.00 mg/str Cyl 1 -2.8 to +2.8 mg/H
-0.14 mg/str Cyl 2 -2.8 to +2.8 mg/H
0.07 mg/str Cyl 3 -2.8 to +2.8 mg/H
0.02 mg/str Cyl 4 -2.8 to +2.8 mg/H
10:37:15 Group 018: PD valve status(after 1 min idling- coolant>80°C)
0.0 Cyl 1 0
0.0 Cyl 2 0
0.0 Cyl 3 0
0.0 Cyl 4 0
10:37:15 Group 023
10.0 (no units)
10.0 (no units)
19.0 (no units)
17.0 (no units)
10:38:10 Group 013: Idle Speed Smooth Running Control
-0.07 mg/str Cyl 1 -2.8 to +2.8 mg/H
0.09 mg/str Cyl 3 -2.8 to +2.8 mg/H
0.07 mg/str Cyl 4 -2.8 to +2.8 mg/H
10:38:10 Group 018: PD valve status(after 1 min idling- coolant>80°C)
0.0 Cyl 1 0
0.0 Cyl 2 0
0.0 Cyl 3 0
0.0 Cyl 4 0
10:38:10 Group 023
6.0 (no units)
9.0 (no units)
18.0 (no units)
13.0 (no units)
Saturday,26,July,2014,10:39:52:46862
10:39:36 Group 013: Idle Speed Smooth Running Control
0.05 mg/str Cyl 1 -2.8 to +2.8 mg/H
-0.05 mg/str Cyl 2 -2.8 to +2.8 mg/H
0.00 mg/str Cyl 3 -2.8 to +2.8 mg/H
-0.02 mg/str Cyl 4 -2.8 to +2.8 mg/H
10:39:36 Group 004
903 /min RPM
1.2 °ATDC Ign. Timing
5.6°KW Idle Stabilization
0.6°KW Idle Stabilization
10:39:36 Group 023
11.0 (no units)
12.0 (no units)
17.0 (no units)
12.0 (no units)
10:39:54 Group 013: Idle Speed Smooth Running Control
0.02 mg/str Cyl 3 -2.8 to +2.8 mg/H
0.00 mg/str Cyl 4 -2.8 to +2.8 mg/H
10:39:54 Group 004
903 /min RPM
10:39:54 Group 023
13.0 (no units)
11.0 (no units)
19.0 (no units)
16.0 (no units)
Napsal: 01 srp 2014, 07:21
od roman1648
INU montujeme běžně, problém zatím nebyl, ta pumpa bude asi GRAF ?
na druhou stranu, je to myslím to nejlevnější co se dá koupit, mimo Starline a podobných shitů..
dneska se dá za pěknej peníz sehnat i origo, nebo třeba sada od Conti popř. SNR
Napsal: 01 srp 2014, 07:28
od sky59
roman1648 píše:INU montujeme běžně, problém zatím nebyl, ta pumpa bude asi GRAF ?
prave ze neviem co je origo? je to to co maju v servise? pumpu ale nemaju..
asi je to naozaj ten Graf, nie je to dobra pumpa? stala asi 40E
Napsal: 01 srp 2014, 07:49
od roman1648
Graf je OK, za 40éček tě pěkně natáhli ;)
kupuju to za 25,-
origo je origo, prostě prvovýroba, v krabici VW-Audi ;) ale jakákoliv značková sada, hlavně ne nějaký Polsko nebo pičínu.. (noteeth)
Napsal: 01 srp 2014, 07:56
od sky59
roman1648 píše:Graf je OK, za 40éček tě pěkně natáhli ;)
kupuju to za 25,-
repasovanu X-ku mi nukali v servise za 50E a novy original za 150E :) to sa mi uz zdalo za pumpu naozaj vela a aj tak ju nastastie nemali tak tam dam ten GRAF
a asi ostanem pri tej sade INA, ten ich original nevedia odkial je....
Napsal: 01 srp 2014, 08:25
od roman1648
to je co za servis...Lamborghini ? (noteeth)
Napsal: 01 srp 2014, 08:46
od blonn
Napsal: 01 srp 2014, 08:47
od Ladas
kdybys hledal umím novou origo Vw sadu za 3500.- včetně pumpy...
Napsal: 01 srp 2014, 08:50
od roman1648
Ladas píše:kdybys hledal umím novou origo Vw sadu za 3500.- včetně pumpy...
no, to by v tom jeho servise dal jen za pumpu... (noteeth)
Napsal: 01 srp 2014, 08:57
od Ladas
kdyby to bylo málo tak pro lepší pocit 4500 (noteeth)
Napsal: 01 srp 2014, 11:20
od sky59
problem je uz iba cas a vzdialenost......
a od koho by to bolo? kto to vyraba?
Napsal: 01 srp 2014, 11:54
od roman1648
no, myslím než pro to jezdit je to lepší poslat...na Slovač to není problém ne (crazy)
kdo to vyrábí nevím no, zavolal bych si do VW Kassel-Baunatal kde je centrální sklad ND pro VW group a zeptal bych se no (rofl)
kladky budou INA, Litens a pumpa Saleri, SKF, těžko říct, ale OEM bývá kvalitativně OK
Napsal: 01 srp 2014, 14:40
od TKTDI
[quote="Ladas"]kdybys hledal umím novou origo Vw sadu za 3500.- včetně pumpy...[/quote
Cau, umis sehnat origo sadu rozvodu vcetne pumpy i na Fabcu SDi kod ASY? Pokud ano, tak za kolik.
Napsal: 01 srp 2014, 14:41
od Ladas
na SDI jen neorig Dayco řemen bílé zuby INA kladky a vodní pumpa Behr-hella 3950.-
Napsal: 01 srp 2014, 14:46
od Jarda S.
s INA rozvodama ani Graf pumpama problém nejni ;)
