Ahojte
nahodou som aktivoval esp aktiv test na octavia 2, problem je v tom ze esp senzor g419 je chybny a neviem dokoncit esp test ... otazka ... viem neako vypnut esp test? kde sa nachadza senzor g419?
ESP aktive test
ESP aktive test
VW Bora 1.9 TDI, rv.99, 225tis km, 81kW@101kW
Skus tento postup:
Kód: Vybrat vše
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 4, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 069
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
Group 006
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Close Controller, Go Back - 06]
