Asi 2,2GB. a uz sem zkoušel i na W764 i 32.   Vse probehne ok.
Ostatni vereze vzdy v poho.ted nemuzu prijit na to co je spatne.
Nejspise 64bit verze a 32nechci preinstalovavat.- /mnoho autoprogramu a diagnostik/
1. Run "Install_x86" or "Install_x64" depending on your OS (32 or 64 bit)
2. Follow on console screen messages and wait for the installation to complete
* Windows 7/8/8.1/10 users MUST do following "a-i" steps while XP users should skip to step 3 *
a) Disable UAC
b) Restart/Reboot your PC
c) Disable Antivirus because the next step is false-positive (NOT virus)
d) Run "dseo13b.exe" as Administrator (<<< this is important) - Enable Test Mode
e) Restart/Reboot your PC (after restart/reboot "Test Mode" will be shown on screen)
f) Disable Antivirus again
g) Run "dseo13b.exe" as Administrator (<<< this is important) - Sign a System File
   It's best to find your own path but depending on your OS it should be:
   32 bit = C:\Program Files\nodongle.biz\AuDaS0\AuDaS0.sys
   64 bit = C:\Program Files (x86)\nodongle.biz\AuDaS0\AuDaS0.sys
   ...and wait for confirmation message
h) Exit from DSEO (dseo13b.exe)
i) Restart/Reboot your PC (those "a-i" steps are for signing emulator, NOT needed for XP)
3) Open "Keygen" folder and Run "GetUid-x86" or "GetUid-x64" as Administrator (<<< this is important) depending on your OS (32 or 64 bit)
4) Now because you have your UID number you can run "keygen.cmd" and paste/enter it to generate "license.reg" registry file (it's important to NOT enter first 2 digits which are probably 64, enter ONLY last 8 digits)
   (in case your UID is 6400000000 you must restart/reboot your PC and go back to step 3 because that UID is NOT proper and valid)
5) Run new generated registry file named "license.reg"
6) Start Emulator as Administrator (<<< this is important) from Start menu or from installed directory which is probably something like C:\Program Files\nodongle.biz\AuDaS0 and there is a file named "ndStart.cmd" or "ndRestart.cmd"
7) Open "Autodata 3.45" from desktop shortcut or ofcourse C:\ADCDA2\ADBCD.exe
   (Any kind of errors related to NOT successfully registered .reg files? Just register them manually from "RegSettings" folder as described at the beginning of this text (before all this steps))
 Enjoy!
