Ahoj,
na prekvapenie mam v tourane 1.9tdi lift 77kW 2009 DSG prevodovku 7 stupnovu - kod prevodovky LSR.
Mam s nou problem, vid diagnostika
Wednesday,24,August,2022,19:10:43:00001
VCDS Version: Release 17.8.1 (x64) Running on Windows 7 x64
www.Ross-Tech.com
Address 02: Auto Trans Labels: 0AM-927-769.clb
Control Module Part Number: 0AM 300 048 G HW: 0AM 927 769 D
Component and/or Version: GSG DSG AG7 431 2475
Software Coding: 0000020
Work Shop Code: WSC 38536 001 1048576
VCID: 3466244C573B6EE645-8060
3 Faults Found:
001854 - Unable to Engage Gear R / Synchronization Gear R failed
P073E - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 289544 km
Time Indication: 0
006000 - Load Signal from ECU
P1770 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 10
Mileage: 289539 km
Time Indication: 0
001824 - Transmission Output Speed Sensor (G195)
P0720 - 000 - Circuit Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 289545 km
Time Indication: 0
Prevodovka za studena ako tak radi, aj cuva spiatocka, ako sa postupne ohrieva olej, zacina kopat, vyhadzovat rychlosti a zacne blikat PRND a spiatocka za tepla nejde vobec... Je to vadna mecha? Co s tym, vie to niekto opravit, alebo sa nemusim trapit a zohnat druhu prevodovku? Vdaka
DSG7 VW touran 1.9TDi 77kW
ALFA ROMEO 75 160ps 200Nm.
Re: DSG7 VW touran 1.9TDi 77kW
vyměn olej a filtr
