PASSAT 3C VIMENA BUDIKU ZA MAXI DIOT
Napsal: 01 čer 2010, 14:56
od pavel33
PROSIM VAS MUZETE MI POMOCT NEBO PORADIT VYMENIL JSEM BUDIKY ZA MAXI DIOT ,UKAZUJE MI SPOTREBU ,DOJEZD,RYCHLOST,KOLIK UJEDU KILOMETRU NA PALIVO ,NEMUZU SE DOSTAT DO MENU DRZEL JSEM PACKU NA TEMPOMATE A NIC ZKOUSEL JSEM I RESET A TAKY NIC ,AKTIVUJE SE MUNU KODOVANIM? ,RADIO SEMI TAKE NEUKAZUJE DIKY VSEM ZA RADY.
(wallbash) (wallbash)
hassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
VIN: WVWZZZ3CZ6E163491 Mileage: 72540km/45074miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
Component: R4 2.0l PPD1.5 G 9627
Revision: --H05--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00625 210 11463
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658564558
Coding: 0013602
Shop #: WSC 00625 210 88544
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005276004
Coding: E1880F0700041A00000A00000F00000000095D435C0000
Shop #: WSC 05311 000 00000
Part No: 3C2 955 119
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Part No: 1K0 955 559 T
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 05 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PRDUQ6D
Coding: 0012341
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507A
Coding: 0000014
Shop #: WSC 00705 210 61656
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 12345 012 36003
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C220A0B
Coding: 3DFD2C04C22003
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2366
Coding: 0000693
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0472
Coding: 199000084103087F3F060F0FC0C84FC6503CE0
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Component: Innenraumueberw.002 0508
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Component: Tuer-SG 024 2802
Coding: 0000692
Shop #: WSC 00028 028 00001
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E3337967
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2505
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
No fault code found. (wallbash) (wallbash) (wallbash)
Napsal: 01 čer 2010, 17:32
od Vaša
není menu přes multifunkční volant ?
Napsal: 01 čer 2010, 18:07
od dodiak
je aj cez packu ale na lavej strane
Napsal: 01 čer 2010, 18:17
od cosby
nemusí jít,jiná verze podvolantovky.Řešil jsem to už asi 3×
verze podvolantovky
Napsal: 02 čer 2010, 14:47
od pavel33
prosim jakej typ verze podvolantovky musi byt ,musi menit i krouzek a spinac zapalovani
dik
Napsal: 02 čer 2010, 14:48
od cosby
nevím,je to dávno a střídal jsem je
Napsal: 31 črc 2010, 14:58
od Alficek
Mám ten samý problém :-( .. na jiném autě to údajně fungovalo, měnil jsem páčky + ŘJ + budíky
Napsal: 31 črc 2010, 15:06
od dream7000
cosby má pravdu, problem bude v podvolantovej RJ, vymenit za verziu HIGH tvoja je MID
Control Module Part Number Software Level Variant LIN Version Note
3C0-953-549-A SW 0010 Midline - -
3C0-953-549-B SW 0010 Highline 1.6 -
3C0-953-549-H SW 0015 Midline - -
3C0-953-549-J SW 0010 Midline - -
3C0-953-549-AC SW 0020 Highline 1.6 -
3C0-953-549-AJ SW 0020 Highline 2.0 -
Napsal: 31 črc 2010, 18:45
od Alficek
Tušil jsem to :-( ... díky za radu ;-)
Ještě jsem našel, že
Midline: Cruise Control, Board Computer
Highline: Cruise Control, Board Computer, Multi-Function Steering Wheel
http://wiki.ross-tech.com/wiki/index.ph ... e_Versions
Divný, MF volant nemám, myslel jsem, že mid bude stačit.
Napsal: 01 srp 2010, 07:12
od sparco gti
mam polodot bez pc,mozem tam dat maxidot?
Napsal: 01 srp 2010, 14:26
od dream7000
ano dat možeš, da sa urobit hocico
Napsal: 01 srp 2010, 20:07
od Alficek
Můj problém s nefunkčním menu vyřešen.
Nevím, co bylo příčinou, ale včera jsem ještě provedl reset budíků a znovu nakodoval gateway s tím samým kodem, který už měla. Pak jsem zkusil dostat se do menu .... nic.
Dnes jsem vlezl do auta a menu se objevilo :-) .... Asi to potřebuje nějakej čas na adaptaci, nebo pomohly ty včerejší operace....
Napsal: 01 srp 2010, 21:19
od dream7000
mozne to je stava sa to ze to nabehne za par hodin.....
Napsal: 19 lis 2010, 22:13
od baciluss
Alficek píše:Tušil jsem to :-( ... díky za radu ;-)
Trochu mi to nejde do hlavy... 3C0 953 549 A je klasifikovana ako Midline a hore pises Midline: Cruise Control, Board Computer.
Dnes som kamosovi skusal aktivovat a aj ked kodovanie bolo prijate tak tempomat nejde :?
Napsal: 20 lis 2010, 08:08
od zx6ninja
u Passata musíš dotáhnout drát do RJ motoru!
