VCDS-LITE
Napsal: 05 čer 2010, 04:15
Function of VCDS-LITE
VCDS-LITE same to VAG-COM 3.11, 409 version!
Don't need special interface!
1. Download cracked VCDS Lite
2. Disable your internet connection
3. Install cracked VCDS Lite
4. Copy the loader into your VCDS Lite directory
5. Run the original VCDS.exe and run the test on your vehicle
6. Use the loader.exe to start VCDS Lite from now on
7. Ensure that your internet connection is disabled whenever you use VCDS-LITE
Good luck!
DOWNLOAD
Good luck!
DOWNLOAD
