Windows roll up with VDS-PRO
VW/Audi/Škoda/Seat
Mathyas
Příspěvek od Mathyas »
The procedure is this:
-Boot the comptuer into real mode dos (win 9x command prompt only, etc)
-Run the vdc_e.exe file in the VDS folder
-Press ESC to cancel the autoconnect...
-Connect your cable
-Connect to the ECU (enter 46)
-Login with code 19283 (function 11)
-Look up and write down your existing memory values (function 26)
-Change the values (function 27)
-Close the connection (function 06)
-Test that things work as they should!
I have boot cd ms-dos with wds pro (iso)
BOOT ISO: Download
Step by step:
Download iso file, after burning to cd...
Booting to MS-DOS:
- Type it in DIR (Enter)
- Start VDS-PRO: VDC_E.EXE (Enter)
- Press ESC, after set the communicational parameters:
Alt-- Configuration-- Connect
Port: COM1
Baudrate: Fixed - 9600Bd
-Write it in if the contact was built up the 46 (Central Comfort...)
Note the PN at the bottom of the screen. I have the 1C0 959 799 B controller.
After logging in... 11 - Login procedure
Password: 19283
Reading the current memory blocks. You must do this for each location and write down what data is currently present, in case you screw up like I did initially and need to go back.
EEPROM read in 26 channel:
Location 0 is what will be changed:
EEPROM write in 27 channel:
Confirmation window:
THE TABLE OF CONTROLLERS
1j0
_______________________________
1J0 959 799 S 03B
Memory Address old value new value
04283 8 2
04289 8 2
08628 242 246 driver side front window
12724 250 254 passenger side front window
16820 250 254 driver side rear window
20916 242 246 passenger side rear window
1J0 959 799 J 00E
04286 8 2
04291 8 2
04296 8 2
1J0 959 799 AH 046 Sedan
04295 138 / 64
04283 138 / 64
04289 138 / 2
08628 242 / 246
12724 250 / 254
16820 242 / 246
20916 250 / 254
1J0 959 799 AH 06Q Sedan
04295 72 / 64
04283 72 / 64
04289 72 / 2
08628 242 / 244
12724 250 / 252
16820 242 / 244
20916 250 / 252
This memory address added to keep the rear trunk handle from locking the car
1c0
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Wagon
04361 75 67
04362 75 67
04363 75 67
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Sedan
04361 74 66
04362 74 66
04363 74 66
1C0 959 799 C (2002 Golf)
04361 138 66
04362 138 66
04363 138 66
1C0 959 799 C (2004 Golf GLS TDI)
04361 138 130
04362 138 130
04363 138 n/c
1C0 959 799 F or 1C0 959 799 G
04361 202 194
04362 202 194
04363 202 194
B5 Passat (1996 - 2000)
1J0 959 799AJ
04283 138 2
04289 138 2
16820 242 246 driver side rear window
20916 250 254 passenger side rear window
1J0 959 799 S 03B
04283 8 2
04289 8 2
1J0 959 799 J 00E
04286 8 2
04291 8 2
04296 8 2
B5.5 Passat (2000 - 2005)
_________________________________
1C0 959 799 A (Wagon)
04361 75 67
04362 75 67
04363 75 67
1C0 959 799 B (Wagon)
04361 75 67
04362 75 67
04363 75 67
04361 74 66
04362 74 66
04363 74 66
1C0 959 799 B (Sedan)
04361 74 66
04362 74 66
04363 74 66
1C0 959 799 C (Wagon)
04361 203 195
04362 203 195
04363 203 195
1C0 959 799 C (Sedan)
04361 202 194
04362 202 194
04363 202 194
New Beetle
1J0 959 799AJ
Memory Address / old value / new value
04283 / 138 / 2
04289 / 138 / 2
08628 / 242 / 246 driver side front window
12724 / 250 / 254 passenger side front window
1C0 959 799 F
04361 / 202 / 194
04362 / 202 / 194
04363 / 202 / 194
1C0 959 799 G
04361 / 202 / 194
04362 / 202 / 194
04363 / 202 / 194
Gti
1J0 959 799AJ
04283 138 2
04289 138 2
Jetta Wagon
1C0 959 799 C (2003 Jetta Wagon TDI)
04361 202 194
04362 202 194
04363 202 194
Polo
6N0 959 799 B 07F
04283 10 2
04289 10 2
4295 10 2
Volkswagen Golf 1J Variant 2004
Adress Old New
04361 73 67
04362 73 67
04363 73 67
Volkswagen Golf 1J 3 (2003)
Adress Old New
04361 10 66
04362 10 66
04363 10 66
Volkswagen Golf (2002)
1C0 959 799 C
Adress Old New
04361 138 66
04362 138 66
04363 138 66
Volkswagen Golf(2004)
Adress Old New
04361 138 130
04362 138 130
04363 138 n/c
Volkswagen Bora Variant (2003)
Adress Old New
04361 202 194
04362 202 194
04363 202 194
Golf 1J
1C0 959 799 F
Adress Old New
04361 202 194
04362 202 194
04363 202 194
Seat Leon(2003)
Adress Old New
04361 10 194
04362 10 194
04363 10 194
Seat Toledo(2003)
Adress Old New
04361 10 67
04362 10 67
04363 10 67
Golf 1J
1C0 959 799 G
Adress Old New
04361 202 194
04362 202 194
04363 202 194
6N0 959 799 B 07F
Adress Old New
04283 10 2
04289 10 2
04295 10 2
Seat Ibiza (6L 2003)
6Q0 959 433 E
Adress Old New
04361 10 2
04362 10 2
04363 10 2
Good luck!
It is necessary to be at this setting pushed the button the pulling up of the window.
This is my problem...
I live in Hungary
