ZÁVADA Č.65535 ŘJ VW SHARAN 1,9TDI RV.97
HELA3
Příspěvek od HELA3 »
POČÍTAČ NAŠEL ZÁVADU Č.65535-ŘÍDÍCÍ JEDNOTKA VADNÁ -SPORADICKÁ ,PŘI VYMAZÁNÍ NASKOČÍ PO CHVÍLI ZNOVU, NEVÍM JESTLI TO SOUVISÍ ,OZÝVÁ SE JAKO-BY CVAKANÍ RELÁTKA V POJISTKOVÉ SKŘÍNI POD PALUBNÍ DESKOU ,MOŽNÁ TO NEMÁ SOUVISLOST ,PROSÍM PORADTĚ ,KDO MÁ JAKÉ ZKUŠENOSTI. VÝKON ZDÁ SE STEJNÝ SPOTŘEBA MOŽNÁ MALINKO STOUPLA ,CHLADNÝ START ZDÁ SE BEZ PROBLÉMU .PŘI MÍRNÉM ZAHŘÁTÍ SE UŽ PROJEVUJE CVAKÁNÍ A TO PŘI PUŠTĚNÍ PLYNOVÉHO PEDÁLU ,ZMÁČKNUTÍ SPOJKY,ŠLÁPNUTÍ NA BRZDY A PŘI AKCELERACI OBČAS.PŘI PLYNULÉ JÍZDĚ Z 80 PROCENT JE KLID .DĚKUJI
