Cvakanie v konfortke ? Octavia 2
Napsal: 22 úno 2011, 18:29
Ahojte, kamos ma problem so svojou octavkou 2. Po cca 10 min od vypnutia zapalovania (kluc zasunuty v zapalovani) mu zacne komfortka vydavat zvuk ako ked cvaka rele. Niekedy mu to robi aj ked otvori a zatvori dvere.
Vedel by niekto pomoct s takymto problemom ? Bol uz aj v skodovke a prehrali mu najnovsi firmware avsak ani to nepomohlo. Mohla by tento problem vyriesit kupa novej jednotky ? Pripadne co asi cca stoji ?
Vdaka !
Toto je vypis z diagnostiky:
VCDS Version: Release 805.1
Data version: 20081017
Tuesday,22,February,2011,17:10:23:26365
Chassis Type: 1K0
Scan: 01 03 04 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: TMBHS61Z982078385 Mileage: 129910km/80722miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9251
Revision: --H07--- Serial number: SKZ7Z0G4537390
Coding: 0000071
Shop #: WSC 73430 790 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R
Component: ClimatronicPQ35 110 0402
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005239382
Coding: 01880F030004140000110D000000000000097F075C000000000000000000
Part No: 1Z1 955 119 C
Component: Wischer 241007 022 0601
Coding: 00055223
Shop #: WSC 73430
2 Faults Found
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 207
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 128662 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q2 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D138DDR
Coding: 0020786
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 812 D HW: 1Z0 920 812 D
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4537390
Coding: 0001101
Shop #: WSC 07860 995 93900
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 128662 km
Time Indication: 0
Date: 2000.00.00
Time: 22:37:49
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 151007F2001863
Coding: E9801F0E0002022302
2 Faults Found
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 128662 km
Time Indication: 0
Date: 2000.00.00
Time: 22:37:50
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 189
Mileage: 127954 km
Time Indication: 0
Date: 2000.00.00
Time: 11:14:31
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1203
Coding: 0000116
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.068 H08 1901
Shop #: WSC 73430 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80D002007F2D8505084B010004CC
Shop #: WSC 08124 234 67330
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000116
Address 56: Radio
Cannot be reached
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
Shop #: WSC 73430 790 08192
1 Fault Found
01545 - Sensor for Parking Aid; Rear Left (G203)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 12
Reset counter: 218
Mileage: 127954 km
Time Indication: 0
Date: 2000.00.00
Time: 11:11:35
End ---------------------------------------------------------------------
Vdaka !
Chassis Type: 1K0
Coding: 0000071
Coding: 0017025
Coding: 00055223
Shop #: WSC 73430
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 207
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 128662 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Coding: 0020786
Coding: 0000042
Coding: 0001101
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 128662 km
Time Indication: 0
Date: 2000.00.00
Time: 22:37:49
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 219
Mileage: 128662 km
Time Indication: 0
Date: 2000.00.00
Time: 22:37:50
Freeze Frame:
Fault Priority: 1
Reset counter: 189
Mileage: 127954 km
Time Indication: 0
Date: 2000.00.00
Time: 11:14:31
Coding: 0000116
Component: KSG 0401
Coding: 0000116
Address 56: Radio
Cannot be reached
Coding: 0000001
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 218
Mileage: 127954 km
Time Indication: 0
Date: 2000.00.00
Time: 11:11:35
