AUDI A6 3.0L TDI rv 2006 BMK motor sama chyba!!!!
zdravim,
s vasou pomocou sa mi podarilo vypnut pipanie pasov, prekodoval som z 2053043 na 2053003 a je pokoj..... /bol tam zly spinac pasy pouzivame! /
v budikoch...
popri tom som pozrel na chyby v motore a skoro som vypadol z auta, tu to je, poprosim vas o nazory ze co tomu je, aj ja idem lustit kody.....
Sunday,07,August,2011,13:33:14:46862
VCDS Version: Release 10.6.0
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4F0 910 409 C HW: 4F0 907 401 C
Component and/or Version: 3.0L V6TDI G000SG 0010
Software Coding: 0011312
Work Shop Code: WSC 02334 785 00200
VCID: 244CEECED881E93C
6 Faults Found
012597 - Intake Manifold Runner Control: Lower Stop not Reached
P3135 - 001 - Upper Limit Exceeded
Freeze Frame
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 254
Mileage: 248190 km
Time Indication: 0
Date: 2011.04.14
Time: 15:00:59
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
P1018 - 001 - Upper Limit Exceeded
Freeze Frame
Fault Priority: 0
Mileage: 248190 km
Time Indication: 0
Date: 2011.04.14
Time: 15:00:59
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 001 - Upper Limit Exceeded
Freeze Frame
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 248190 km
Time Indication: 0
Date: 2011.04.14
Time: 17:02:59
Freeze Frame
RPM: 882 /min
Torque: 70.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Duty Cycle: 25.3 %
Temperature: 31.5°C
001025 - EGR System: Insufficient Flow
P0401 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 79
Mileage: 248192 km
Time Indication: 0
Date: 2011.04.14
Time: 17:12:00
Freeze Frame
RPM: 1890 /min
Torque: 109.2 Nm
Speed: 44.8 km/h
Duty Cycle: 71.7 %
Duty Cycle: 20.9 %
(no units): 211.5
Duty Cycle: 16.6 %
005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
P161D - 001 - Upper Limit Exceeded
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 254908 km
Time Indication: 0
Date: 2011.06.13
Time: 07:16:53
Freeze Frame
RPM: 882 /min
Torque: 109.2 Nm
Speed: 4.5 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 24.5 %
Temperature: 17.1°C
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 001 - Upper Limit Exceeded
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 255234 km
Time Indication: 0
Date: 2011.06.20
Time: 07:20:11
Freeze Frame
RPM: 1470 /min
Torque: 42.9 Nm
Speed: 10.1 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Duty Cycle: 29.2 %
Temperature: 14.4°C
Readiness: 1 3 0 0 0
v budikoch...
6 Faults Found
Freeze Frame
Fault Priority: 0
Mileage: 248190 km
Time Indication: 0
Date: 2011.04.14
Time: 15:00:59
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Freeze Frame
Fault Priority: 0
Mileage: 248190 km
Time Indication: 0
Date: 2011.04.14
Time: 15:00:59
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 248190 km
Time Indication: 0
Date: 2011.04.14
Time: 17:02:59
Freeze Frame
RPM: 882 /min
Torque: 70.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Duty Cycle: 25.3 %
Temperature: 31.5°C
Freeze Frame
Fault Priority: 0
Fault Frequency: 79
Mileage: 248192 km
Time Indication: 0
Date: 2011.04.14
Time: 17:12:00
Freeze Frame
RPM: 1890 /min
Torque: 109.2 Nm
Speed: 44.8 km/h
Duty Cycle: 71.7 %
Duty Cycle: 20.9 %
(no units): 211.5
Duty Cycle: 16.6 %
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 254908 km
Time Indication: 0
Date: 2011.06.13
Time: 07:16:53
Freeze Frame
RPM: 882 /min
Torque: 109.2 Nm
Speed: 4.5 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 24.5 %
Temperature: 17.1°C
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 255234 km
Time Indication: 0
Date: 2011.06.20
Time: 07:20:11
Freeze Frame
RPM: 1470 /min
Torque: 42.9 Nm
Speed: 10.1 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Duty Cycle: 29.2 %
Temperature: 14.4°C
Kupena v maji 2003
dlhodoba spotreba 5.1
spotreba pri 80 4.2L/100km
Kupena v maji 2003
dikychosepm píše:Dej nový žhavicí svíčky a podívej se na táhlo, nebo funkci klapky 2.řady válců...
Bank1 = 059 129 711 CG
Bank2 = 059 129 712 BL malo by sa jednat o tento na Bank2 z toho by malo byt jasne ci pravy alebo lavy
Ty nahodou nevies na ktorej strane to je ked pozeram spredu stojaci do motora?
Kupena v maji 2003
Kupena v maji 2003
podle toho kteřý motor odpojíš tak poznáš co je 1 a 2 a asi budeš donucen měnit sání i s klapkama protože motorek to nevyléčí..
tie klapky su ovladane elektrickym mortorcekom?Ladas píše:podle toho kteřý motor odpojíš tak poznáš co je 1 a 2 a asi budeš donucen měnit sání i s klapkama protože motorek to nevyléčí..
Kupena v maji 2003
Kupena v maji 2003
skymann píše:Ano,su ovladane servom.2-ka je na strane vodica(pri lavostrannom riadeni) a inak plati co pise Ladas-komplet.
diky chalani za rady,
dnes so zase pobrowsoval a zistil som, ze od nejakeho casu maju celoplastove /ulozenie/ klapiek vyrabat s kovovymi prstencami, co by uz malo vydrzat....
je to svagrove auto a v servise audi ani nevedeli ktora strana to je
ked som v nedelu cital chyby este som nevedel co viem dnes a preto sa chcem spytat: je moznost vo VCDS 10.6.0 /VAG/ spustit nejaky test aby klapky behali od zavretia do otvorenia? a opakovane... mozno je chyba aj niekde inde....? pri stojacom motore...
podla fotografii co om nasiel tak poloha klapky sa snima v tom telese motorceka, co ak je chyba iba tam a mechanika klapiek je v poriadku?
je to rv 2006 mozno su tam uz tie kovove ulozenia... ak by som zlozil privod vzduchu dole, da sa asi vidiet to ulozenie?
este raz som na to pozrel a mam za to, ze snimac polohy klapky je iba v telese toho servomotorceka, nesnima sa fyzicka poloha tych troch klapiek (?)
ak by som dal dole to rameno co prenasa pohyb zo serva na klapky tak by chyba mala zmiznut ak problem robia tie klapky, mam pravdu?
ak je chyba v serve tak chyba zostane aj nadalej, totiz ta chyba sa prejavuje aj pri stojacom motore
ako sa da na skusku demontovat to ramienko? je tam nejaka zavlacka?
diky za info
Kupena v maji 2003
Kupena v maji 2003
- farkihome
najnovsia revizia nema kovove ulozenie klapiek. je to skor nejaky druh odolnejsieho plastu, ktory vyzera trosku ako teflon.
je to svagrove auto a v servise audi ani nevedeli ktora strana to je Smile
je mozne spustit adaptaciu klapky, ale to zial nepomoze. problem je jednak v klapkach, ktore su vylajbane a hlavne v tiahle, ktore sa normalne vyderie, takze dorazove hodnoty su mimo tolerancie 20 - 80%. menil som to na Touaregu 2007.
podla fotografii co som nasiel tak poloha klapky sa snima v tom telese motorceka, co ak je chyba iba tam a mechanika klapiek je v poriadku?
mozne to je, ale je to malo pravdepodobne. menit zvlast motor alebo len teleso klapiek je k nicomu, kedze sa to neda zadaptovat. nove klapky su uz v nejakej tusim 5 revizii.
neda sa vidiet a urcite nie su kovove. je to naozaj velmi bezna zavada tychto motorov. ja som uz menil obe. na novych je inak riesene tiahlo aj ulozenie klapiek.
nemas. klapky totiz nejdu 0-100% ale 20-80%.
ak je chyba v serve tak chyba zostane aj nadalej, totiz ta chyba sa prejavuje aj pri stojacom motore.
pri stojacom to robi aj mne. vtedy klapky urobia pohyb od 20 - 80%.
zavlacka nie je, da sa to dat dole silou. mne to slo dole v pohode, spat uz tazsie, ale dal som to 2 krat, takze pohoda. snazil som sa klapku opravit, vymedzit pohyb, nedal som to. musel som ju vymenit. stoji cca. 380 - 390 EUR.
diky za info
diky za info
farkihome píše:diky chalani za rady,
diky za info
vdaka, takze doporucujes vymenit obe strany naraz kedze je to systematicka chyba?
teraz uz len asi zo zvedavosti by som sa rad na to pozrel, ci NAHODOU nebude chyba nejaka ina, ale asi nie.... ale zvedavost a 1000E je velka
motivacia
a neskusal si nahodou ze ci pri zhodenych ramienkach chyba zmizne? to by potvrdzovalo ze je chyba v klapkach samotnych, ale pokial chyba nezmizne by boli vadne iba servomotorceky, mylim sa?
a ta vola toho hriadelu s klapkami je nejaka velka? da sa citit "hrkanie" v ruke ked tym "potrasiem"?
STALE MI TO VRTA V HLAVE TOTO JE DOEDITOVANE:
ked si stiahnes SSP_350.pdf je to o tom motore a nie je tam naozaj ziaden snimac polohy klapky, vid aj prilozene foto celeho nasavania, vsak si ho sam menil, urcite si nepripajal ziadne kabliky okrem toho konektora na motore?
druhe foto je foto otvoreneho serva/motora, vidiet ze je tam uP na riadenie polohy plus komunikacia
preto si myslim, ze treba skusit zhodit obe ramienka na oboch stranach a vymazat chyby, pokial sa znovu chyby objavia tak je zle servo a spodok netreba menit, pripadne opravit servo
este je jedna moznost, ze by sa servo spoliehalo na mechanicke dorazy klapiek? potom by pripadne vole na hriadeli vedeli vyvolat chybu...
a teda bez tych tyciek by to stale hadzalo chyby
Kupena v maji 2003
Kupena v maji 2003
a nasiel som aj riesenie, vsetko nasvedcuje tomu ze system spolieha na mechanicke dorzy klapiek, zrejme podla prudo motorceka co to otaca...
tu je riesenie s hlinikovou lepiacou paskou
Kupena v maji 2003
Kupena v maji 2003
- urgi
Je to bez zavad teraz ?
A napadlo ma co tak vysustruzit nejake mosadzne vlozky alebo na klbik teflonovu pasku
a tak so googlil a tu je skoro vsetko
http://www.volkspage.net/technik/ssp/index4_eng.php
?dakujem za navod k super pdf-om taketo som hladal 2 rokysky59 píše:ked si stiahnes SSP_350.pdf
Naposledy upravil(a) urgi dne 09 srp 2011, 19:02, celkem upraveno 2 x.
OOOO A7 ENGINE 4G 3.0 TDI 09/2011 motor CDUC 245HP / 7 gear s-tronic
- farkihome
je to tak ako pises, len motory be klapky behaju 0-100%, doraz je mechanicky, ktory sa pohybuje v rozmedzi 20-80%. ja som bol tiez ovela viac zvedavy ako som chcel investovat 400 EUR, tak som najprv zhodil klapku, vymedzil osku klapiek, kedze lietala +-2mm, ale tiahla boli na strane klapky zoslahane, t.j. motor nezastal na 20% ale siel az do 18%, co je mimo toleranciu a hadzalo mi to chybu. principialne to na motore nezbadas, lebo sanie ma dva ventily, pricom jeden kanal je furt otvoreny a druhy sa otvara iba pri load-e motora. ked je chybna klapka, ide na maximalne otvorenie pocas celeho otackoveho spektra. myslim, ze ta Al folia je silno docasne riesenie. ale je, to nepopieram. naprd je, ze soudruzi z NDR nedodavaju diely klapky samostatne. dala by sa opravit za par supov. ma totiz demontovatelne klapky, ulozenia klapiek aj vymedzenie osky sa da menit. diely vsak na to neexistuju. nove tiahla vsak maju novu konstrukciu, je to klasicky klb, ktory je zapuzdreny. skus pospekulovat, ale vsetko je to zial len docasne.
farkihome píše:je to tak ako pises, len motory be klapky behaju 0-100%, doraz je mechanicky, ktory sa pohybuje v rozmedzi 20-80%. ja som bol tiez ovela viac zvedavy ako som chcel investovat 400 EUR, tak som najprv zhodil klapku, vymedzil osku klapiek, kedze lietala +-2mm, ale tiahla boli na strane klapky zoslahane, t.j. motor nezastal na 20% ale siel az do 18%, co je mimo toleranciu a hadzalo mi to chybu. principialne to na motore nezbadas, lebo sanie ma dva ventily, pricom jeden kanal je furt otvoreny a druhy sa otvara iba pri load-e motora. ked je chybna klapka, ide na maximalne otvorenie pocas celeho otackoveho spektra. myslim, ze ta Al folia je silno docasne riesenie. ale je, to nepopieram. naprd je, ze soudruzi z NDR nedodavaju diely klapky samostatne. dala by sa opravit za par supov. ma totiz demontovatelne klapky, ulozenia klapiek aj vymedzenie osky sa da menit. diely vsak na to neexistuju. nove tiahla vsak maju novu konstrukciu, je to klasicky klb, ktory je zapuzdreny. skus pospekulovat, ale vsetko je to zial len docasne.
chalani, diky za namety a rady a nemozem to tu nazvat inak ako "kolektivny mozog"
este som to nepaskoval ale aj na to pride a myslim si, ze ak tam dam trosku silikonovej vazeliny moze to byt dlhodobe silne docasne riesenie
Kupena v maji 2003
Kupena v maji 2003
ono sa to derie aj vo vnutri? mas na mysli to ulozenie hriadela na ktorom su tie tri klapky? to ulozenie by malo byt 6 nasobne? a co by mohlo spadnut do motora? vsetko co sa hybe vnytri toho nasavania je kovove, nie? kovovy hriadel a kovove klapky? akurat to debili ulozili v nejakom plaste...?farkihome píše:len daj bacha na jednu vec. tie klapky sa deru fakt jak fras. aby sa nevydrali tak, ze ti nejaka cast padne do sania. to by mohlo byt pre motor fatalne. zvazil by som to. inak vybrat ju nie je az taky problem.
Kupena v maji 2003
Kupena v maji 2003
