nj ale to mu asi moc nepomůže stou spotřebouStingray píše:chlape radsej chod do americkeho diesel motora - 6valec 24ventil v biturbe dava spickovo 1200koni. Mas nato vsetko hotove staci len kliknut a kupit.
vhodný motor
Libor Hanzal
vhodný motor
Jenže todle je prcek H3.
- Stingray
Re: vhodný motor
to je jedno aj H3 je mackopes - duramax dieselLibor Hanzal píše:Jenže todle je prcek H3.
Do H3 pasuje napriklad V8 6.6diesel
The Duramax Power Train conversion consists of removing the stock engine, transmission and transfer case and replacing with the Duramax Engine, Allison Heavy Duty 5-speed Transmission and selectable 2wd/4wd transfer case. Each conversion consists of a brand new engine, transmission, and transfer case. Depending upon the conversion it will take us from 4 days to several weeks depending upon upgrades and custom options. Additional, custom and one off upgrades, are available such as paint, suspension, interior work, exterior styling options and various theme builds. The Duramax conversion will now enables you to operate a selectable 2wd/4wd system which increases fuel economy up to 22mpg. During the conversion, many new items are installed such as a new intercooler, fuel cooler, Duramax Wiring Harness, Modified ECM and several hundred other items that go into the massive conversion process.
...to be or not to be... - faster
Libor Hanzal
vhodný motor
Marku,proč měnit benzín za stejně žravej diesel.Já bych to viděl na pětivál z T4 111kw. Dostal bych se možná na 9litrů a ještě využiju olej z restaurace.
