kontrolka airbag nevypne - Audi A4 B8
Kosto
Příspěvek od Kosto »
Ahojte,
znicoho nic mi vyskocila kontrola airbag na palubovnej doske a nechce vypnut, pozeral som chybne kody cez VCDS a nic nevypisalo len xenon range a este jednu control module - tieto chyby tam mam vzdy.
Kde moze byt chyby a ako tu kontrolku viem vypnut ?
(pozeral som kable v priechodke medzi dverami aj pod sedadlom a nic neobvykle som si nevysimol)
Dik za radu
Audi A4 B8 2.0 CAGA
UchoTD
Příspěvek od UchoTD »
Musi byt nejaká DTC v airbagu.
Alebo je vypnutý spolujazdcov airbag.
Mitsubishi Outlander 2.2DID
Mitsubishi SpaceStar 1.3MPI
VW T5 lift T6 140kw
Škoda Superb 2.0TDI 4x4
Kosto
UchoTD píše:Musi byt nejaká DTC v airbagu.
Address 17: Instruments (J285)
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 14:36:06
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 15:46:14
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 8
Reset counter: 121
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 15:00:24
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000006720787
Coding: 011002204000410001
Shop #: WSC 06325 000 00000
VCID: 3F8DA577AE8867E6AD9-806A
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 14:44:36
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000056521
Shop #: WSC 00000 000 00000
VCID: 2F6DF5377EE897663D9-807A
No fault code found.
Address 55: Xenon Range Labels: 8K0-907-357.clb
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 63
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 14:37:37
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
2 Faults Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 63
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 15:00:18
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 63
Mileage: 209398 km
Time Indication: 0
Date: 2018.12.26
Time: 15:00:18
V DTC airbagu sa nenachadzala ziadna chyba. Toto su vsetky chyby z RJ. Ktora chyba moze mat to ze mi stale v budikoch svieti airbag ?
Audi A4 B8 2.0 CAGA
UchoTD
Kodovanie jednotky airbagov dodaj a pozri ci nieje vypnutý spolujazdcov airbag
VW T5 lift T6 140kw
Kosto
UchoTD píše:Kodovanie jednotky airbagov dodaj a pozri ci nieje vypnutý spolujazdcov airbag
Ako myslis kodovanie jedotky ? Mozes mi to viac specifikovat ? No vypnuty airbag neba byt preco, nakolko ta ikonka mi zacala svietit zo dna na den a nic sa s autom nerobilo. Teda tyzden pred tym sa menili silentbloky motora, lenze po vymene sa chyba neukazala, az asi tyzden nato. Myslel som ci pri vymene senzorov sa nepohybal senzor airbagu niekde v predu, ale to by asi hned vyskocilo aj v DTC ?
BTW. vypninanie spolujazdzoceho airbagu nemam v aute aktivne, teda nemam ziadne tlacitkom resp. ten vypinac - toto bolo len na doplatkove vybavy.
Audi A4 B8 2.0 CAGA
rami
Příspěvek od rami »
Nemuze mit vliv na tu kontrolku ta chyba v pristrojovce ?
Kosto
rami píše:Nemuze mit vliv na tu kontrolku ta chyba v pristrojovce ?
myslis tato?
1 Fault Found:
tuto tam mam odkedy som kupil auto uz 4 roky a kontrolka airbagu nesvietila. Ale prave to googlim a idem to skusit dat do basic settings
Hosi nejake napady ? nie a nie prist na to preco svieti ta kontrolka, VCDS neukazuje ziadnu chybu stale :/
Audi A4 B8 2.0 CAGA
