Ahoj mam u sebe Opel Astra H 1.7 cdti rv 2006 - obcas se stane ze nejdou vypnout svetla a nebo se spousti sami vystrazny blikny a nejde sporadicky nastartovat. Nevite cim by to mohlo byt?
Zde je vypis ecu:
Engine ( 3 ) Abnormal
P0500-74 Vehicle Speed Signal
Range/Performance
Not
Present
P0650-74 CAN-Bus No Communication with CIM
(Steering Column Module)
Invalid
P0500-5B Vehicle Speed Signal
Range/Performance
Invalid
EHPS
(Electrohydraulic
Power Steering)
( 1 ) Abnormal
C1523-03 System Voltage Low Voltage Not
Present
XL/TIS (Exterior
Lighting/Turn
Indicator System)
( 1 ) Abnormal
U2116-00 CAN-Bus No Communication with IPC
(Instrument)
Not
Present
IL (Interior
Lighting)
( 1 ) Abnormal
(Instrument)
Not
Present
W&W
(Wipers/Washer)
( 1 ) Abnormal
(Instrument)
Not
Present
CDL (Central Door
Lock)
( 1 ) Abnormal
(Instrument)
Not
Present
IC (Instrument
Cluster)
( 1 ) Abnormal
(Instrument)
Not
Present
IMMO
(Immobiliser)
( 1 ) Abnormal
(Instrument)
Not
Present
ATW (Anti Theft
Warning System)
( 1 ) Abnormal
(Instrument)
Not
Present
CIM (Steering
Column Module)
( 3 ) Abnormal
B3925 Wrong Environment Identifier Received
IPC (Instrument)
Not
Present
U2100-C CAN-Bus Communication Malfunction Not
Present
U2116-CD CAN-BUS No Communication With IPC
(Instrument)
Not
Present
SRS (Supplemental
Inflatable
Restraint System)
( 1 ) Abnormal
U2116 Invalid Data From IPC (Instrument) Not
Present
REC (Rear
Electrical Centre)
( 1 ) Abnormal
Present
UEC (Underhood
Electrical Centre)
( 1 ) Abnormal
Present
IPC (Instrument
Control Unit)
( 4 ) Abnormal
B3150 Central Door Lock Switch Stuck Not
Present
B1456 Automatic Light Switch Circuit Open Not
Present
B3909 Low Beam Switch Circuit Open Or High
Voltage
Not
Present¨
B3596 Hazard Warning Switch stuck Not
Present
DIS (Info Display
TID,BID,GID,CID)
( 1 ) Abnormal
(Instrument)
Not
Present
opel astra h - sporadicky nejdou vypnout svetla a spousti se
