Kód: Vybrat vše
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Mileage: 209884 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Mileage: 209884 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01111010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 244
Mileage: 206441 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 210092 km
Time Indication: 0
Date: 2000.00.00
Time: 08:05:36
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 1
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 210092 km
Time Indication: 0
Date: 2000.00.00
Time: 08:05:36
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 249
Mileage: 209519 km
Time Indication: 0
Date: 2000.00.00
Time: 05:47:09
Freeze Frame:
Voltage: 14.20 V
Speed: 0.0 km/h
ABS 1
02630 - Voltage Supply for Swivel Module Position Sensor; Right
007 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 249
Mileage: 209519 km
Time Indication: 0
Date: 2000.00.00
Time: 05:47:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 5
Time Indication: 0
Freeze Frame:
Voltage: 10.93 V
Speed: 0.0 km/h
ABS 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 5
Time Indication: 0
02628 - Sensor for Swivel Module Position; Right
Freeze Frame:
Fault Status: 11100111
Fault Priority: 3
Fault Frequency: 254
Reset counter: 244
Mileage: 203065 km
Time Indication: 0
Date: 2000.00.00
Time: 10:22:36
Freeze Frame:
Voltage: 14.34 V
Speed: 57.2 km/h
ABS 1
Freeze Frame:
Fault Priority: 3
Reset counter: 244
Mileage: 203065 km
Time Indication: 0
Date: 2000.00.00
Time: 10:22:36
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 209884 km
Time Indication: 0
Date: 2000.00.00
Time: 15:05:09
Freeze Frame:
Voltage: 11.08 V
Speed: 0.0 km/h
ABS 1
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 209884 km
Time Indication: 0
Date: 2000.00.00
Time: 15:05:09
