Auto cuká při volnoběhu
jakerossman
Příspěvek od jakerossman »
Cutting laminate sheets tutorial for beginners by Joseph French
If you want to Learn How To Cut Laminate At Home, I have the perfect guide for you. Conducted by Joseph French - the leading writer at SycamoreReview - this cutting Laminate sheets tutorial should be simple enough to follow, even for beginners. Let’s jump right into it.
The preparation
The first thing you need to do before cutting Laminate sheets is measure the installation area. Use a tape measure to get all the lengths and widths you need. Then, calculate the total areas and add 5% to 10% for sparing.
Then, remove the existing laminate sheets that you want to replace. Temporarily cover that area up if you do not install new ones right away. Make sure to clean all the stubborn residue before making any replacements.
Another thing that should be done to prepare for cutting Laminate sheets is letting the sheets expand for 27 hours. Leave them in the room where you need the installation for the planks to get familiar with the common temperature and humidity so they won’t shrink or warp after installation.
Finally, choose a cutting tool to help you with the job. It’s also the time to sharpen the blade for smooth and clean cuts which will reduce so much effort during the process. If you are sensitive to fine dust, prepare a mask and working goggles to protect yourself. A pair of safety gloves are more than welcome to join the working outfit.
The execution
Let’s officially learn how to cut Laminate at home by following this tutorial:
  • Step 1: Lay the laminate sheet on an even surface.
  • Step 2: Measure and mark the cut line on the laminate sheet. Remember to use a non-permanent marker to prevent staining the sheet. For those particular shapes, it’s best to draw a guide on a piece of paper and trace that shape onto the laminate sheet to get the most accurate guideline.
  • Step 3: Place a bucket under the cutting area to collect the dust and residue during the process. Also, put on protective gear before moving on to the next step.
  • Step 4: Use the cutting tool of your choice to cut along the guideline. You may need to use different tools to make straight cuts and curve cuts.
  • Step 5: Carefully snap the sheet to remove the piece you need. Score the sheet to deepen the line if needed to create the cleanest snap. The trick is to pull the needed piece towards you.
Repeat these steps until you have all the laminate planks you need for installation.
Further Reading:
How To Cut Laminate With Simple Methods
How To Cut Laminate: A Comprehensive Guide
The installation
Make sure that the area is clean to prepare for installing new laminate sheets. Install any underlayment you need and then place the cut laminate sheets on top. Tuck them into place and try moving the sheets to see if they are fit to the spot or not. Finally, vacuum and mop the surface to finish.
I believe by following this simple tutorial on how to cut laminate sheets by Joseph French, you can have this DIY project done in no time without any trouble along the way. Remember to visit SycamoreReview for more useful tutorials like this in the future.
