Nevim zda podle logu z dsg jsou ty kilometry opravdu skutecne?? udajne 655000km?????
auto ma 177000km i stav tomu odpovida.......
je mozne ze to pise nesmyslne cislo nebo prevodovka ma opravdu 655000km???
Mate nekdo zkusenosti zda km vzdy sedi???
viz log z VCDS
Friday,12,May,2023,16:20:46:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.3.0.1 (x64)
Data version: 20220225 DS336.1
www.Ross-Tech.com
VIN: TMBJH7NP8J7521326 License Plate:
Address 02: Auto Trans (0GC 300 042 H)
16:20:43
IDE02820 Transmission mileage 232.6 km
IDE03171-ENG102987 Driving strategy transmission mileage-Q002 Total Driving Time 237.9 km
IDE05987-ENG110508 Engine stop prohibitions-km-Stand des letzten Stoppverbots 0.0 km
IDE06243-ENG120894 Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection 0 km
IDE12712-ENG36173 Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage 0.0 km
IDE12713-ENG36135 Clutch friction coefficient model mileage-Gearbox mileage 232.6 km
IDE13947-ENG36805 Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection 655340 km
IDE80002-ENG102386 Analysis 2-Snapshot 1 Mileage 0 km
IDE80034-ENG101047 Analysis 34-Snapshot 2 Mileage 0 km
IDE80276-ENG127854 Current vehicle odometer reading-Current vehicle mileage 177509 km
IDE80277-ENG127828 Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage 0 km
IDE80278-ENG127882 Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage 0 km
Suberb 3 2018 110kw 7DSG skutecne km prevodovky?
- Sběrač informací
Naposledy upravil(a) šulda dne 15 kvě 2023, 16:10, celkem upraveno 1 x.
Důvod: Úprava názvu tématu.
Re: Suberb 3 2018 110kw 7DSG zkutecne km prevodovky?
Údaje v DSG by mali približne sedieť...čo mám ja info, tak upraviť km v DSG nie je úplne jednoduché...mne to sedí s rozdielom asi 10 alebo 100 km, už si to nepamätám, je to možno 2 roky čo som to pozeral na žiadosť jedného klubáka.
VW CC 2017, 2.0 TDi 135kw, DSG R-Line, Kessy, ACC, DCC, XDS, Discover Media, R19 AEZ Kaiman, R18 Mallory (zima)
zvykne sa stat ze to ukazuje chybne udaje, ja mam original vcds a sem tam vo vypise vidim napr.datum 2084...takze bude to asi chyba prekladu, obavam sa ze pri 655..by bol ten voz uz zrely na recyklaciu
- Sběrač informací
Re: Suberb 3 2018 110kw 7DSG skutecne km prevodovky?
Tak vyreseno....jine vozy maji tu hodnotu taky 655350km takze to tam je z nejakeho duvodu normalni
Takze prevodovka ma 230km najeto a motor 177000km
Vypada i nove takze byla z nejakeho duvodu menena:-(
