nefunkčná klíma a palubný PC
Napsal: 23 dub 2006, 20:03
Nazdar borci.
SEAT IBIZA 2001 1.9 TDI AGR
Mám 2 problémy:
Odkedy som kúpil auto (2 roky), neukazuje mi na spoločnom displeji (klíma + rádio) dáta z PC.
Je tam zobrazená hodnota: -- -- C
Ďalej mi prestala teraz fungovať automaticka klimatizácia. Bol som u chladničkára a tlak v systéme je OK.
Tak som si dnes postavil prevodník na RS 232 a prečítal som diagnostiku.
Prosím mrknite na to, sú tam nejaké chyby. Poraďte prosím.
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 EC
Component: 1,9l R4 EDC 0000SG 2147
Coding: 00002
Shop #: WSC 06402
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 06406
Shop #: WSC 00000
Address 08 -------------------------------------------------------
Controller: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00625 - Vehicle Speed Signal
27-00 - Implausible Signal
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6K0 920 801 E
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00142
Shop #: WSC 04362
IMMO-IDENTNR: SEZ7Z0A1114501
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 56 -------------------------------------------------------
Controller: 6K0 035 156 A
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
2 Faults Found:
01465 - Signal wiring from Combi-instrument
49-00 - No Communications
End -------------------------------------------------------
Mám 2 problémy:
Coding: 00002
Shop #: WSC 06402
Coding: 06406
Shop #: WSC 00000
2 Faults Found:
Coding: 00142
Shop #: WSC 04362
1 Fault Found:
35-00 - -
No Faults Found
Coding: 00401
Shop #: WSC 06402
2 Faults Found:
