Nowadays, vacuum cleaners have become an extremely familiar item for every household. However, after a period of use, your Shark apex uplight vacuum cleaner burned for unknown reasons. The burning of the vacuum cleaner will affect the cleaning process as well as costly maintenance. Today, we will learn together what causes a vacuum cleaner to burn and find a remedy for that case!
The Causes
There are many reasons why the shark apex vacuum cleaner gets hot quickly during operation. The hot and burning situation is mainly caused by the following causes:
The machine is clogged with suction nozzles, pipes, filter bags
A blockage anywhere in the air passage when entering the vacuum cleaner can lead to a drop in pressure in the suction line.
After that, the motor will have to work at total capacity, leading to overheating.
In addition, many types of vacuum cleaners can also self-cool the motor by using the exhaust fan to the rear of the machine.
In case the exhaust pipe of the machine is blocked, it will reduce the amount of air, the motor is not cooled enough, and eventually lead to heat and fire.
The motor shaft is stuck
After a period of use, you will notice that the dust cup of the machine is full. Along with that, the rotating neck of the device may be dry due to too much activity.
In addition, a jammed motor will also easily lead to increased heat in the built-in electromagnetic coils.
Motor quality is poor
If you buy a machine at a low price, it means that the components in the device are also of low quality, especially the electric motor.
Usually, the motor of a cheap vacuum cleaner will use an aluminum core coil. As a result, the quality is not durable and leads to a rapid increase in heat that causes the vacuum cleaner to overheat.
Important Site: Shark APEX UpLight review: Is it as sustainable as advertised
The power supply is not guaranteed
If the power source your home uses often changes frequency or jumps automatically, it is also easy to cause the vacuum cleaner's motor to jump, unstable, and easily catch fire and damage.
Using the wrong vacuum cleaner
Improper use of a vacuum cleaner can also be one of the common causes of engine overheating.
Specifically, some mistakes are using continuously for many hours, choosing a dusting brush head that is not suitable for the floor or floor you are cleaning, not regularly emptying the cup or dust bag included in the machine.
The above reasons can also cause your machine to overheat and burn.
Measures to fix
Here is how to fix the hot vacuum cleaner situation that you can refer to:
- Regularly check and unclog dust in machine components and clean equipment according to the manufacturer's instructions. If you cannot clean it yourself, contact the store where you purchased the product and ask a professional to do it instead.
- If the vacuum cleaner heats up because your power supply is unstable, you need to check your power supply to ensure the amount of power for the machine to work.
- If your motor is burned or damaged, please bring it to the shop or service center for repair in the fastest time.
