HELP EROR CODE P1594 a P1874
rktech
Příspěvek od rktech »
Ahojte kamos ma golf 5 16 tku simos jednotka .Auto po nejakom case ide do nudzaku a diagnostika launch x 431 napise tieto dva kody P1594 a P1874 neviete co znamenaju ?
VAG nenasiel ziadnu chybu 805 verzia ..
toyota.kzj
Příspěvek od toyota.kzj »
18282/P1874/006260
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 18282/P1874/006260 - Valve for Torque Support Mount: Short to Plus
1.1 Possible Causes
1.2 Possible Solutions
1.3 Special Notes
Possible Causes
Valve for Torque Support Mount faulty
Wiring/Connectors from/to Valve for Torque Support Mount faulty
Possible Solutions
Check Valve for Torque Support Mount
Check Wiring/Connectors from/to Valve for Torque Support Mount
Special Notes
When found in Audi A8 (4E): 3.7l/4.2l/4.0l TDI or 6.0l Engine, check TPL/TSB 2006451.
Due to changes in the Production Process the Valve may not be used anymore and requires further steps.
Retrieved from "http://wiki.ross-tech.com/index.php/18282/P1874/006260"
Category: Fault Codes
a nebo si to prohledej tady :http://wiki.ross-tech.com/index.php?tit ... ntil=01537
Zpět na „Evropské vozy - ostatní“
